Technical  space saver
fronteratech
manchester
is it possible to fit normal size wheel instead of space saver also what models do they also fit 1.9 multijet 2006.
it has alloys fitted would like an alloy or steel spare not sure of the offset etc
I have a 57 plate 'family' model and it has a full size spare.
Should be able to fit normal size wheel, based on what I 'cut & paste' from the owner's manual ......
When you have finished [*changing the flat tyre]
1) Arrange the wheel you have replaced in the specific housing under the floor bed and secure the safety wire A [fig. 14a] into clip B.
2) Hook the top of support bracket C [fig. 15] to the anchoring ring D and tighten the support locking bolt [fig. 6].
In certain Passengers Transport versions instead of the traditional spare wheel, a space-saver spare wheel is provided. For anchoring to support proceed as follows:
– If the space-saver spare wheel is used, the spacer pad cannot be refitted on the outer side of the standard wheel rim but it shall be stowed temporarily in the luggage compartment.
