pghstochaj said:
I am trying to say this is wrong, the denser the material the less it absorbs (less air gaps) and the more it reflects. Absorption relies on a material being pourous for attenuation, reflection relies on a different sort of interface (in my course, we concentrated on absorption and active noise control, not reflection, so can't comment much on that!) However, I also can't comment on what would be required in the car as I don't actually know the desired outcome of it lol. If it was proofing through remving energy, something like a foam works and if reflection, something dense would work
I was specifically disagreeing with that single "The denser the material, the more it absorbed"
I think we may be both agreeing and disagreeing with each other here. My comment could have been a little clearer as to the type of sound absorption.
I completely accept that if we are talking about, for example, concert halls, then the wall and ceiling material would preferably be a lighter, more open surfaced material to 'absorb' sound by allowing it to pass through and subsequently prevent it being reflected back into the auditorium. A person on the other side of the ceiling tile would hear the sound almost unabated, as the sound would not be 'absorbed' by the material.
For a semi-detached house, however, your stereo system would drive the neighbours mad if the walls were very lightweight, because they would do the same as the aforementioned ceiling. In that case, a nice heavy brick or block would 'absorb' the sound by effectively cutting down the pass-through volume, but would do
as you say and reflect the sound back into the room.
(All of this is, of course, dependent upon the thickness of the material, ie: 50mm of polystyrene vs 50mm of Brown Bread for example)
Your sub box, for example, is made out of heavy MDF and thick fibreglass, so as to form a solid enclosure, and give the best sound whilst preventing any buzzing or vibration. The density helps channel the sound, increasing the sub's effect.
Perhaps I was a little at cross-purposes and could have been clearer. What I meant was the choice of material dictates the 'pass-through' qualities of the insulation, whereas you are talking more about the 'reflective' qualities. So in that case, your comment is entirely correct. I can certainly see what you mean in the context of the reflective qualities of sound-proofing materials.
It's easy to see how misunderstandings occur. Sorry for the confusion.
Tosh
(Definitely
not trying to start a flame war)
