Punto (Mk1) somebody please help
djechouk
Does anybody know what radiator fan cable harness will fit my Punto GT off another fiat I no there must be one out there off a different model punto,i can't get an original so am stuck my old one is broken finally died
is it the fan that’s not kicking in ? it could be the relay/ fuse or the temp switch , found a nos one on eBay from Greece but it’s around £140 with postage , item 232847647494[emoji33]. If it’s just the fan maybe the brushes in the motor could be replaced , the TD one could be similar but I think the ones of the other models are different
Yeh fan not working replaced fan switch think the whole loom is finished as I only had secondary fan cutting in anyways, my fan stayed on once and I tried to disconnect to get it to turn off and then next thing i heard like a pop then bit of smoke came from connection switch so Duno wat happened I presumed I messed up fan switch so replaced that but fan still don't come on ? aint checked relay or fuse so will do that next propably need a resistor too but can't find it anywhere online ? my mechanic said I can probably get it made by an electrician but will probably need the resistor.i think I have messed up the connector just had a load of work done too car is running sweet apart from this so not gona drive it till I resolve this problem I can take a pic of connector I pulled off
Fan is good I'm sure can easy bypass that to check it's defo the cable harness that I need as it was mashed from before only had 1 connection to fan hence the problem only secondary cutting in once I find and fit that then I can figure the rest out no 2 in the picture this is just a catalogue but cannot actually order the item someone sent me link Wen I was asking but we're do I get it from once I chosen the items I need.shall I fone fiat main dealer, dam this is gona annoy me lol
