Some sort of Popping/Blowing
G
Griffy (BravoT350)
When i press accelarator, there is a slight delay then pops and low revs, notice this wen i change gear aswel, would this be the exhaust manifold gasket blowing? because seems to loose pressure wen i change gear and then car jolts a bit wen i engage clutch as enginge speed seems to have slowed down bit more than it should after releasing accelarator wen changing gear.
What kind of noise ?
Spark pugs are old /new ?
Members Site - - - - - - - My Site
spark plugs new, dun bout 500 miles, bought new a month ago. Champion ones.
think it does judder abit, nothin shows on rev counter, 1.2 it is. Just sounds like a tractor lol, press pedal, slight delay, think revs even go down a split second after i press pedal.
how do u check the lambda sensor, what i looking for?
think the diagnostic check will cover it - but not 100% sure
do the above stuff first then report - and whait, you will get more answers (Tom ;))
there is one hose, the main one goin from intake behind grille to filter box, seems to be bit short,
if i fully put it on onside, its half off on the other, could it be that?
A
2
857
Tommy K
T
1
7K
Dark Lurker
M
1
387
M
V
5
732
Laurie
L
M
431
M
