I wouldn't be so quick to lay the blame of smoke on oil being burned.
Burning oil can be caused by many things, leaking valve seals, worn valve guides, worn piston rings and/or bore linings, turbo oil seals, etc.
However, burning oil has a completely different smell to unburned diesel.
Oil has a sickly sweet smell, whereas diesel is rank and catches in your throat.
I have a similar situation with my Doblo 1.9. Some pikey a-hole stole the DPF, leaving a gaping wound in the exhaust system. The smoke was coming out from the middle of the car and when I jacked it up I found the damage.
I put a straight pipe on in the meantime, but when the car has done around 10 miles at 70mph, it want's to regenerate to clear the DPF as it doesn't know it's missing.
The stink is awful and looks for all the world like burning oil as it is thick grey/white smoke. But it definitely stinks of unburnt fuel.
If you say it smells of oil I will have to take your word as I am not there.
All turbo's tend to leak a small amount of oil via the seal, I would worry if they didn't
A cup full of oil in the intercooler is possibly the result of the age of the vehicle and it could well be that which is being burned, who know's?
So, now you have a MIL lit up, I would hazard a guess that it is because you have disconnected various sensors, EGR, MAF, etc. The fault codes will need to be deleted and see if they re-occur upon start up.
A reasonably good little code reader is available on Ebay for around 14 quid
http://www.ebay.co.uk/itm/Car-Auto-...iagnostic_Tools_Equipment&hash=item33836e8912
I have one to supplement my older OmiScan and it works well.. You get a book with all the "P" codes used in EOBD2 (European On Board Diagnostics series 2) and the only trouble it has is with reading a DPF that isn't there (but should be). It thinks it is a second (bank 2) cat and/or oxy sensor fault. As far as I can tell, the Doblo 2 (facelift) 1.9 JTD only has one cat and one oxy sensor, so if it comes up bank 2, there should be a DPF.....I stand to be corrected....
The last of the 2005's "may" have had a DPF fitted, but usually at the end of that run for that year. All 2006 on registered vehicles had to have them by law.
Anyway, confusing it is, but my first suggestion is change oil and all filters. My diesel filter cost me (trade) almost 40 quid
so I imagine you will be around 50 or 60 quid.
Oil has to be 10w 40 and apparently Valvoline is best for these motors. I used Mobil 1 and still got that God awful warning to change the oil
However, I know it's been done, even if the patient thinks it hasn't
Check the oil level before changing, is it high? If so, it is possible you have a run off of diesel from faulty injectors slowly filling the sump and over flowing into the inlet. This can be extremely dangerous in that it could build up and be sucked in via the inlet, causing a runaway engine.
A runaway is when the engine starts running on its own sump oil. Since a diesel is compression ignition, it requires no sparks to ignite the fuel and will run and run at high revs until it runs out of oil, then it may seize or throw a rod.
That is a possibility, it doesn't always happen. But who knows how well it was serviced previously?!?!
Then I would have the injectors flow tested, cheaper than removing the head and replacing all the gaskets.
Once again, are you certain it's oil being burned?
A bit of slack in the turbine is ok. It runs on a bearing of oil, so needs a bit of room for the shaft to float in the flow of oil. If it was tight, the oil couldn't flow
So, check all connections are tight in the electrical sensors.
Check all pipes on inlet and exhaust. Intercooling pipes on these are complicated, but easy to spot a loose hose. Less easy, but just as likely is a hole in a rubber intercooler pipe near the gearbox. They can be guilty of rubbing a hole, creating running problems like a misfire and smoking on boost.
Write a list and check off what you have looked at.
Happy New Year
