usually turbo oil seals, maybe blocked breather, piston rings or stem seals, head gasket, if headgasket your water & oil will probibly mix so youl find oil in the water and water in with the oil
if you take the pipe off from the airflow meter to the turbo you will be able to fit your fingers in the turbo and check for play, if there is lots of play then id say turbo
