Technical Slight issue at last service
SiloSean
Long story short, last time I serviced my 1.3 mjet 4x4, when changing the air filter I hit a snag that I have never come across before. When tightening down the screws to secure the cover, one screw would not tighten all the way down, it won't unscrew either. It seems that the bit it threads into is now loose. I am getting to the point that I will need to service it again in a coming months, but not sure how to get the screw out other than to cut it off. Guess that I'm going to need a new air box. Anyone had anything like this?
Believe the part number for the air box is 51946541
Model
Panda 1.3 Multijet 4x4
2013
Mileage
93000
Eh up
If it’s spinning, it’s not catching on owt, I’d undo all the others then carefully lever straight up equally all the way round. It will pop the cover off, just go carefully. Once of cut, remove the old screw. Go next size up and it should bite in, or drop some plastic weld in the old casing hole and then same size screw in , it will cut its own thread just go slowly like if you were cutting a thread.
Eh up
Or insert a walled thread insert. Then use a standard screw rather than the self tapper. This might give you more of the concept. https://uk.spirol.com/assets/files/ins-threaded-inserts-design-guide-uk.pdf
Eh up
Does seem like whatever it screws into has sheared, thus just spins without actually doing anything. I guess I might be able to remove the air box without taking out the filter. Have a look under to see if I can find a break. I have done a bit of plastic welding before, so should be able to sort something.
