Technical  Skydome Q&A
Normal grease (the kind of thick one).
Open the roof all the way then lay some grease with your finger in front of the sliding arm that holds the glass. After that, close and open the roof once or twice to spread the grease on the tracks.
Don't use those silicone sprays, they dry out almost instantly and they flush the grease so you endup with a stuck roof.
Note that you should have a torx handle stashed in your user manual, it's used to manually crank the roof when the motor or battery is dead.
Hey guys,
About the looks, I got a white Bravo two weeks ago (I'm a big fan of the Maranello Red or Black or my favorite Blue) but here in Mexico they just sold it out back in 2009 (yep, just 1 year due to the conversion of MXN to EUR) and got mine white (used with 47000Kms).
I just love it, it was an only version (the Sport one) so it has black interiors with blue triming and it looks wonderful, and with the tinted windows and tinted roof it looks like a very much expensive Audi A3 or even a S3....
About the roof not being able to open/close it with the remote is due to its weight and its motor to just work with the engine running). My battery just died this morning.... :(
I would say the Panaroof is the main feature that makes the Bravo stand out.And importantly,it attracts attention from the chicks:D
Opened my roof today and it now refuses to close. It sometimes goes a little way, gives up and opens again? Any experience or ideas would be greatly appreciated due to the impending rain tomorrow!!
Mine came with a manual crank to close the roof in just this eventuality. Never used it but the handbook says it fits in the slot under the plastic cover behind the rear sun roof.
Yep, just found it. I've re greased the front runners but it still can't close under it's own steam and make a clicking noise while trying. I've found the manual overide and closed it so at least it's not going to get wet. Do the rear runners run dry? They look like rollers but I couldn't really see.
Had the same issue and had to take it to the garage. They disassembled and reassembled it. Greasing it every year since then - no issues.
There's a service combination with the buttons to reset, i believe you have to hold the two buttons together. But didn't fix anything in my case.
You need to grease it and check the rubber cover on the outside it could be blocking the arms holding the glass.
Do you mean the rear runners? I'm sure it's going to be something like that. It opens fine but just can't shut under it's own steam. I won't get a chance to have a look today, got to entertain the kids and the weather doesn't look great either.
Does someone fancy doing a quick guide of how they grease the roof, and what grease they use out of interest :confused:
A good indicator that your roof needs greasing before it completely stops moving is that clicking noise you hear when it's moving.
Whenever I hear that noise, I grease it.
Got that noise when it's trying to close.(y)
I've downloaded the Elearn manual to get some direction. When the weather is good, I'm off work and free of kids I'll get to it. When I was having a quick look at the manual it recommended using Vaseline on the runners, there must be better than that?
I've tried to open it this morning to assess the runners and the drive has broken completely so the bloody thing is now stuck in my drive with a sheet over it and I'm stuck without a car. My Fiat is certainly living up to the stereotype.
