Silly question..
Silly question..
S
Smee
is the tick over of a 1.6 very noisy.... cos my car after i heated it up it very loud still i always thought it would be dead silient but it aint... should i be worrying....
sorry for silly question
Smee
i dont think there is anything much wrong... if anything... maybe a gasket some where some 1 must have an idea????
plz if so i got to book my car in for morning to get repaired
Smee
Re: Re: Silly question..
Try turning the engine off, its quieter that way. :)
What SORT of noise do you hear?
Re: Re: Re: Silly question..
sounds like the tappets.... but i thought they adjusted to stop.... are the self adjusters or can they be put out of line... sort of gave her some stick earlier... and she was ticking before but my mind tells me she ticks more.... most prob ok
Smee
Re: Re: Re: Re: Silly question..
It's 16v and can cope with a thrape. Mine sounds tappety every so often, just be sure and keep the oil topped up ;) and you'll be right.
Re: Re: Re: Re: Re: Silly question..
im sounds tappety all the time
Smee
Re: Re: Re: Re: Re: Re: Silly question..
16 valves, 16 tappets, lots of noise.
What grade oil are you using? 10W40 I hope.
Re: Re: Re: Re: Re: Re: Re: Silly question..
yep helfords stuff... service soon.... so i think ill get them to do a major one and change everythhing including clutch and gearbos
Smee
p.s thanks for ur help u 2
Re: Re: Re: Re: Re: Re: Re: Re: Silly question..
Don't change the clutch unless you have to, its all too easy to damage the starter when doing it.
Does the noise go away if you press the clutch down?
can i have your gear box?
lol
Re: Re: Re: Re: Re: Re: Re: Re: Re: Silly question..
the thrust bearing has gone or one of the bearing in the gearbox.... (that rattling sound i moaned about).... so i thought **** it ill get it all done.... 36000miles on clock and it has a bit of stick so i think clutch is going
Smee
B
2
542
BRUNO
B
4
509
Darren
N
1
937
Ozric-Al
O
