General  Silly question but....?
remove the sparkplug cover (torx bolts) its the big plate on top of the engine.
you will see 5 coils. under each coil is a sparkplug. to remove a coil you need to remove the 2 bolts on it, disconnect the wiring harness, then give it a good pull.
now remove the sparkplug using a plug spanner (make sure the rubber ring is in place to lift the plug out with) if you dont have a plug spanner with a rubber ring inside, you can use a coil to grip a plug and pull it out once it is unscrewed.
(y)
