romniox789
I recently bought a 499cc 110F and have had to replace the carb (it has a new, stock Weber 26) and a refurbed distributor with new points and condensor (properly gapped) so I am setting the car up again. I think I've got the carb about right - 1.5 turns on the mixture seems to run nicely, idilng according to my electronic tacho at about 800 give or take 50rpm. Much lower on the idle or the mixture and it starts to cough.
But with timing I'm really quite confused. I got the car running by setting static 10 degrees. Now I have a strobe light, and the timing plate and I don't know how I should be aduusting.
What timing mark should the strobe show at my 800rpm idle - 10 degrees, 0 degrees, something else?
What should the idle speed even be? There's nothing in my haynes and nothing in the workshop manual I can see (maybe I'm looking in the wrong place!)
How does the 28 degree mark factor into anything - when should the strobe light align to that?
I presume the 28 degree mark is the fabled 18 degrees that I keep reading about on top of the 10 baseline?
Many thanks for any help to solve my confusion...!
- Model
- 110 F 499cc
- Year
- 1972
