theoneandonly
Prominent member
Many sensors have a common system of connection
Eg
A +5V, earth, sence value typicaly .2 to 4.8V
The +5V is typicaly supplied via the ecu with some common pins. There maybe more than one common. Same for earth connections.
B +12V, sence, 0V via body earth.
There seems to be a common type of issue with ducatos ie chaffing, conductor/ connector corrosion leading to shorts and opens.
Is there a list of these locations for each model, specificaly for X290 and latter as little Fiat info and theres a lot more sensors. I will hapily take older stuff.
If no list exists please add any known here with as much info as possible and i will compile as a guide.
Even just pointing to a thread with info will help.
Eg
