GreySquirrel
- Joined
- Mar 31, 2005
- Messages
- 11
- Points
- 4
I have a Stilo Abarth Selespeed on an 02 plate. I've had it a while (4 years) and have got used to it's little peculiarities but it's now starting to run "rough".
The gearbox failure warning used to come on from time to time when you went round a right hand corner and was low on oil. Top up the oil and problem goes away. I now have what I think is a legitimate problem with the clutch speed sensor (comes up as such on diagnostic). On start up the car runs very poorly until the "choke" comes off (idle comes down from 1200 to 700 rpm). It's fine out of gear but when driving it jerks and kangaroos mentally. After warming up it is much better but in all forward gears is laggy until about 4500 rpm. A bit like someone is strangling the car. In reverse it has no problem AT ALL, even on start up. In other words, I can plant it in reverse and I nearly go through the windscreen!
This is why I'm assuming it is a gearbox problem, some sensor (most likely the one that errors sometimes - clutch speed sensor) is having trouble relaying correct information to the ECU and therefore runs rough. I've heard that the gearbox sensors can get dirty and can be taken out and cleaned without the need to remove the gearbox. I've had a look on the car itself as the ePer online parts system (http://www.spangerum.com:7080) doesn't note the sensors. But I can't find what I'm looking for. Can anyone point me in the right direction or knows what this issue could be?
Appreciate any help at all!
