Seicento Sporting Michael Schumacher in faded red
Just picked up one of these for a 70 mile a day commute and so far, great fun.
It's a 2001 Y reg, 80k miles, full service history, new rad, alternator, battery, handbrake cables, clutch and clutch cable and exhaust were done by the previous owner.
So far ( 20 miles in ) i've fixed the following ...
Seized cooling fan and a blown fuse, WD40 on fan bearings and a new fuse fixed that.
Leaking sunroof - removed all the bolts and siliconed up the rubber washers, new gaskets made from bike inner tube and silicon greased the seal. No more leaks.
Things i might fix ...
Both fog lights are not working, one definitely due to water through a cracked lens and the other .... probably got bored years ago.
Clunking from the steering, presume / assume it's either track rod ends or balljoints / arb bushes.
Paint - it's a faded sorry state, good enough condition, just looks like FIAT forgot to put suntan lotion in the original paint
The only thing i'm stuck with now are what tyres to get, have seen you can get Pirelli P6000 175 50 R15 or 165 60 R14 in more choices, am inclined to go for the higher profile as it's cheaper and will probably dent the mpg less. I take it there are no issues with using a 165 60 R14 tyre on that wheel? Miata tyre calculator reckons it's within tolerance
175/50-14 3.4in 10.4in 20.9in 65.6in 965 0.0%
165/60-14 3.9in 10.9in 21.8in 68.5in 925 4.3%
Bit more searching reckons 185 50 R14 will fit - Maxxis do their MA Z1 in that size and that'll do fine. Will get 4 of those ordered and fitted next month - i'll play with what's left of the P6000s for now
I'm aware this won't sharpen the handling but that's fine.
Since everyone on forums likes pics, here's a few of it, nicknamed it 'Shooey' which seems entirely apt. Outside is faded in many places, once i get some time i'll buzz the DA over it and give it a few coats of decent wax but i suspect the paint has faded beyond help. It is utterly manky inside but now the leaking roof is fixed ( and its no longer carrying a dog around) i'll get in there with an aquavac and make it a lot nicer
