My 2001 Fiat Seicento sx (1.1) had a bad ecu. It has the IAW 59f m7 46817821 coded one. The problem was that the 1-4 cylinder ignition coil went wrong and that killed that part in the ECU, so these cylinders have misfires. I can't find the same ECU but if so then very expensive but I found an IAW 59f m3 hw303 for 2001 punto 1.2 8v for cheap with everything (key, fuse box etc) for cheaper than the Seicento ECU itself. My question is, would the engine start if I reassembled the car with all the new parts?
Any compatibility with this car?
Thanks for the help!
