- Joined
- May 1, 2014
- Messages
- 273
- Points
- 170
Hello guys,
I think I have a problem.
It seems that my differential gear is leaking on both sides; I think there is a little play if I shake the driveshafts (I'm not speaking of the little play that cv joints have: I have grabbed the shaft where it exit from the differential gear, before the inner cv joint).
As you can see, it seems that there is a leakage from there (although I'm not entirely sure of that, because there are other source of leakage).
Have you ever change the differential gear bearings and ring seals?
