Hello friends!
It seems I only come on here when I want something
In the middle of an engine swap on a friend's 2000 1100 Sei. It has air con and one of the identifying factors preceding her arrival was the extreme squeek since found to be an idler or guide pulley which goes between the alternator and the air con pump.
My local motor factor looked straight through me and my local Fiat stealer sucked through his teeth and basically told me to ring them 3 weeks next February.
If anyone knows what the proper name is and even better, have a part number, or even better-erer actually have one for sale I'd be most grateful.
Also, does anyone know when the teeth on the timing belt and pulleys changed? I think our replacement engine is a later type as the belt & water pump we've been given by the factor have different spacing between the rubber teeth than that on the original.
Any ideas?
Cheers!!!
Any ideas?
Cheers!!!
