Technical  Sei Sporting ('00) front fogs
Huddersfield
Hey all ... my drivers side fog light was out so I bought replacement bulbs - figured I may as well do them both while I was at it. I managed to get the pasenger side foglight out and changed no bother but the driver's side one is c&*t if you'll excuse my french...
It's so close to the radiator that I can't see a way to get it out easily. Will I have to remove the front bumper and is that a fairly simple task?
Also, having changed the passenger side one, the whole unit seemed to be really (and I mean REALLY) badly erroded (I would have said corroded but that didn't seem to fit since it was full of what looked like sand!). Is this a common issue? Should the unit also be reflective inside, as it seems to be a strange dark red - almost terracotta - coloured paint (the same as the exterior which is also all flaking off)?
Shouldnt need to remove front bumper a la driver side one.
The sand/crap in the foglight seems to be cropping up more and more, mine went the same way and so have others, would change it as well
I maybe shoulda been a bit more specific - the bolts came out no issue so the light is detached from the bumper. But getting it out from there so I can actually change the bulb is the issue.
Don't know if it's ever been replaced as I've only owned the car a few months but it only had 19k on the clock when I bought so I doubt it.
Would like to replace them completely Kris but can't really afford it atm ... bulbs were free from a Halfrauds employee ;)
Just for everyones info I finally got it out (not easily) by removing the belly pan and - rather harshly - bending the bumper until it basically fell out. Turned out the whole casing was shot to hell so even if I had replaced the bulb it would have gone again at the first sign of water. So i'll be onto Ebay at some point to get a replacement pair, figure I may as well change them both while I'm at it ...
