f1ian
Hi All.
I am looking to upgrade the wheels and tyres on my Sei Sporting. I am currently on 13" and want to stay like that. Unfashionable maybe but it's what i want and Yokohama make some great track tyres in 175/50 x 13
Anyway, its the wheels choice that i am stuck with, I understand that Sei/Cinq have around 30-38 for the offset but i have 27.5 cast into the wheel.
Since the rear wheels are close to the arm at the back anyway, i thought i should "Measure Twice, Spend Once" so i popped off a front wheel to check. I have a 5mm spacer on the hub - is that normal since i don't have Abarth wheels? - and i measured from the back of the wheel where it contacts the hub to the back edge of the rim. I measured 115mm.
So where does 27.5 come into it??? Or 30-38mm offset for that matter?
I plan to stick at 5.5 or 6 x 13 so nothing too radical but there is a lot better choice of wheel at 4 x 100 PCD so i was thinking to use PCD adapters as i don't like wobble bolts. The adapters are all around 20mm thick so that could complicate things. I dont want to end up with wheels outside the arches or upsetting the steering feel. The alternative is to get a set of custom wheels made but at what offset?
Thanks in advance for any advice.
