AbarthMarco
Hello, everyone! Being directly...
I am from Brazil, and I've got a 2008 Fiat Grande Punto HLX 1.8 that had been abandoned for about 2 years, in addition to staying in a flood, the GM engine was rebuilt and the gearbox was reused, but I believe it has been water damaged, anyways.
At the beginning, shifting gears were pretty bad, but recently I fixed the shifter, everything was fine, but even with that, second gear grinds when trying to shift and not engage and the reverse gear is also very difficult to engage, and when it engages, it escapes.
Is there a problem with the gearbox itself, or with the shifter? Because the 1st, 3rd, 4th (surprisingly works) and the 5th gears engage without any problem, and only the 2nd and the reverse have this grind and engage problem, anyone have experienced this or have any idea, tip or solution for this?
* illustrative image *
