Gary196721
- Joined
- Sep 28, 2007
- Messages
- 40
- Points
- 17
Hi there, Just bought 1.9 53 plate, and I have a couple of probs that I would be very appreciative for some help and advice on.
1. Spinning Lock barrels. I gather from reading some post that this is a very comon problem, attributable to the 'security' feature that spins the lock if it doesn't recognise the key. I managed to free-off the drivers door lock with some patience and WD40. Would a freshly cut key help any?
2. Heater doesn't function. I've read some post with regards to removing the fan/heater assembly for inspection, and am pretty clear on that. However, I'm not as clear on what and where to test, and what faults I should be looking for. (I know my way around a Multimeter) I thought the first thing I should check should be the fuse, but can anyone tell me what number the fuse for the heater is. Had a look but there's loads.
Winter is already kicking in up here in Jock land, so I need to get the heater working!! So I'd be very appreciative of any help you can give me on any of my questions.
Thanks, Gary. :shrug:
