I Hope this helps guys
Wife was complaining about screenwash constantly emptying. Leak somewhere ?
2020 Fiat500x
* Tell tale sign "wet footwell in rear behind front passenger side and mildew sitting ontop of carpet"
* Rear washer supply pipe runs with wiring loom under carpet along internal sill
* Remove plastic trim along floor sill besides the passenger seat. Trim will pop off on plugs, however to completly remove there is a 10mm plastic nut alongside rear seat.
* This now reveals wiring loom with black corrugated water pipe about 8mm in diameter.
* Flick of washer switch will reveal split in the pipe.
* Cut the pipe and "Bridge with rubber washer pipe and 2x straight through connectors
* Repair kit on amazon for £9
* I vacumed water out of footwell and lifted carpet and stuffed towel under to absorb as much as possible
* Wd40 wiring to displace water
In my opinion the water pipe is run far too tight and is also brittle
Windscreen washer pump is located behind wheelarch lining passenger front side. Turning wheel full lock to left will give access. You will see access hatch to it in linner. 2 x plastic grommets to remove.
Disclaimer
I am not a mechanic or suitable trained. And this was my experiance only. I have shared it to contribute to ethos of forum.
2020 Fiat500x
Disclaimer
- Model
- 500x
- Year
- 2020
- Mileage
- 25000
