Scudo (Mk1/Mk2) screen wash
ronw
Hi i am new to this fiat forum site, Can any member help ,I have just got a 1999 scudo
to kit out for some fishing trips , but have found the screen wash is not working no motor .For some reason Haynes did not make manaul. Would like to knon where fuse is and washer bottle / pump please.:bang:
There's a diagram of the 1999 Scudo fuse box you can download from post #2 of this thread: https://www.fiatforum.com/scudo/223576-fuse-number-listing.html?p=2424609
It says the fuse box is located behind a removeable panel below the steering wheel.
It says that fuse number 24 is for the windscreen washer, however the same fuse is also used for the windscreen wipers. So unless both your wipers and washers don't work, it's unlikely to be a fuse problem.
Hi i am new to this fiat forum site, Can any member help Would like to know where fuse is and washer bottle / pump please.
Hi and welcome
Washer bottle usually under the front wing
Clear plastic tank..easy to spot
This miniguide might give some info too :
https://www.fiatforum.com/miscellaneous-guides/418889-flush-out-dead-clogged-screenwash-pump-tank-focus-tdci.html?p=4022772
Charlie
