Don't use thinners.
Depending on how big an area you're trying to recover.
If its a small area, maybe the size of a shoe box lid, then you'll probably get away with doing it by hand.
Using a cutting compound, and working on the paint you want to remove, (try to avoid the good paint) rub and rub and rub till your arms fall off.
Eventually the rubbish paint will come off revealing the paint underneath.
You'll need to keep it well lubricated to avoid burning, so use lots of compound and don't be afraid to use a little water.
If your'e really brave a combination of compound, water and P3000 wet & dry paper will speed things up, but will also get you in to trouble pretty quickly if your'e not careful.
Alternatively, one of those buffing machines (look a bit like an angle grinder), will speed things up a little.
If it's a large area like a whole wing, then you've got your work cut out.
We used to swear by 'Faracle' cutting compound, which comes in various grades. This is what the pro painters use.
It's still available, Fleabay has tons of ads.
