Technical Scantool for 2.2 with SGW
Has anyone got any recommendations for bi directional scan-tools for above. and how to access the Fiat gateway if required
I have tried some of the cheaper tools on my 2022 Ducato 2.2 but found various problems when using them. What finally worked perfectly was the following:
MultiEcuScan, OBDLink EX, and an SGW Bypass such as this one from Gendan SGW Bypass - although you can find the same thing on eBay for half the price.
If I remember correctly you will also need the Blue and Grey coloured adapter cables.
AlfaOBD also works with that setup but was missing a lot of parameters compared with MultiEcuScan.
I have tried some of the cheaper tools on my 2022 Ducato but found various problems when using them. What finally worked perfectly was the following:
As I have mentioned elsewhere, before you purchase , check that it is actually compatible with your vehicle.
I was going to the MES route until I found that my 2010 Fiat Scudo 2.0 was not on it's list due to it having the Peugeot engine so I had to buy MaxiEcu scan tool which I have been very happy with and you can add on other car makers for a small fee. It runs on Windows O/S.
Not saying your vehicle would not work with MES, just saying check first.:)
