Running on 3 cylinders... dangerous?
P
Paul S
The coil pack does not seem to be distributing charge to all four cylinders. Is there any immediate danger in running the car on 3 or is is just a lack of power?
PAul
Yes, you will kill the cat.
Are you SURE its the coilpack? What engine is it? If its a 1.4, 1.6 or possibly a 1.2 as well then the coils feed 2 cylinders so a faulty coil pack would kill 2, not just 1.
Re: Re: Running on 3 cylinders... dangerous?
are you being hip when you say kill the cat or is it a technical term? What damage will it do? we have been driving for three days with it like this....oops
Re: Re: Re: Running on 3 cylinders... dangerous?
If there is unburnt fuel getting into the catalytic converter it will overheat and can melt.
Re: Re: Re: Re: Running on 3 cylinders... dangerous?
hence a strong smell of fumes???
Re: Re: Re: Re: Re: Running on 3 cylinders... dangerous?
Bingo!
Again, are you sure its the coil pack and not the plug leads?
Re: Re: Re: Re: Re: Re: Running on 3 cylinders... dangerous?
I wouldn't be able to tell but the mechanic seemed pretty sure....will get it checked just in case. is the damage still done???
Re: Re: Re: Re: Re: Re: Re: Running on 3 cylinders... dangerous?
I would not like to say, you will have to see.
Change the plug leads!
N
6K
N
F
7K
F1-ANG
F
M
6
419
Dark Lurker
E
1K
E
