Anybody else's rpm gauge make a "chattering" noise on start up at the point when it sweeps to the 6 o'clock position when starting the engine?
Ignore that it's doing it againWell disconnecting the battery seems to have stopped it for now allthrough the "big" seems to come and go all the time so will see how long it stays away
Looks to me like it's starting from the wrong location; if it fixed itself when you disconnected the battery but then lost the setting again it could be the stepper motor's on the way out, or the motor's shaft has got corroded somehow. Might be worth pulling the cluster out, removing the cover, taking the needle off, giving the shaft a gentle clean, plug it all back in and put the shaft on position '0' once it's done it's calibration to see if that fixes it...
If it doesn't work, are you any good at soldering?
Edit: another thing it might be - if the rpm needle normally has a little pin just past 0 to find it's rest position and the pin's fallen out, that'd cause it too; if that is the case you'll hear a little rattle when you take the cluster out, or might see a small hole where the pin should be if you peer closely at the rev counter.
Edit2: Woah!
Presumably wrong for your car, but that might give some clue as to which pins to point a multimeter at, if you get that far inside the speedo cluster
I thought as much for the doc I found, but interesting to see how much depth people have gone into for the gauge in the past; I thought it was pretty impressiveThe pictures are for a classic Tipo so will be nothing like a modern one
As for it not starting in the right position I'm fairly sure that where it allways start from even when it dosnt do that noise
All the other cluster I've seen online rest at the 6 position when not running so I doubt there's any sort of pin missit prehaps somebody else with a Tipo can post what there cluster doesI thought as much for the doc I found, but interesting to see how much depth people have gone into for the gauge in the past; I thought it was pretty impressiveYou'll probably find similar test points on a modern pcb to above though if you need to pick up the signals passed through though.
As for the starting position, maybe that is normal (others would know better than me) but it does seem quite unusual to start from below 0 rpm and complete the sweep half way up; if it's not able to find it's zeroing point (some rev counters do use a little pin as a zero point) it'd be more likely to 'panic' so to speak when in operation. Worth a quick check just in case before condemning the instrument cluster (assuming you don't decide to put up with the issue) since popping a little pin back in is a quick cheap option, if that's all it is.
Seems odd the battery gauge on the dash still showed around 2/3 but obviously isn't very accurate and it still spun around Fairly quickly but then again it's a Fairly low compression engine on the 1.4 16vAlmost certainly, its the battery.
When the voltage starts to drop weird things happen
One ordered £73 decided 59 pay little more for a efb type even though it doesn't have start stop only another £14 should hopefully make it last a little longer good brand as well yussaAlmost certain that'll be the battery - my Tipo did it at the start of the year. The battery had gone flat once over Christmas & been charged by the dealer, but then the juddering gauges started. The car continued to start fine for quite a while but with the dials doing the juddering, then it gave up again. Dealer ran a battery test & it failed so Fiat replaced it under warranty and no repeat of the problem since. If its just the 95bhp 1.4 then a new battery shouldn't be too costly as there's no start-stop on them if I remember correctly?
