Technical rounded off torx bolt
Did you use a torx socket or try a normal socket?
First clean and soak the opposite end with plenty of propper release oil (not wd 40.) and a wire brush
Then lightly warm the threaded end a kettle of boiling water should suffice (they are thread locked)
Get the propper socket( e19 from memory) a decent socket that's a bit tight and hammer it on (safety glasses) then apply a slight tightening torque before undoing ( keep blathering it with release oil) if it becomes tight wind it back in slightly and wire brush the threads
When replacing the bolt order a genuine fiat one
its the ones at the top got one of them off and the other is so tight im looking at removers but due to it being easter every wheres shut tomorrow. i dont know what else to do as it is so round. thinking hit a 10mm over and use airgun? hopefully it will work as running out of options :(
Have you got access to a mig welder?
If 'yes' and all else fails you could try building up a decent stud up of weld and weld on a sizeable nut to allow you to get a decent ring spanner of it.
A mate of mine done the above on a snap off bolt and it worked a treat.
