General rough starting p0340
cremulator
hi
my fiat doblo 1.9 multi jet is taking ages to start
I've plugged it into multiecuscan and it comes back with code p0340 cam shaft position sensor
will this be the problem?
looking at this forum lots of post say crankshaft sensor
is the camshaft sensor the same as the crankshaft sensor?
the work I've had done not so long ago
3000 miles ago new timing belt kit and water pump fiat parts
3000 miles ago full service all fiat parts
thanks for the help
the car has been in the garage today to get the camshaft sensor replaced and it still has the same problem p0340 code
anyone got any ideas
thank you
Check the wiring to it, if need be get an auto electrician to check the wiring, it must be the wiring or the ECU, I would put my money on wiring.
Still I don't know the circuit, so can't say any more.
the car is in at the auto electrician on thursday so hopfully get to the bottom of the problem
Update
went to auto electrician on thursday
he checked the car over and said it was a faulty cam shaft sensor
as he is not getting no return signal from the sensor but hes getting signal from the ecu to the cam sensor
so ive paid £60 for a cam sensor from eurocarparts and it was a bosch and its fautly and i paid for it to get installed . the best part is eurocarparts do not accept and returns on electrical components. will not be using them again
so ive bought 1 from fiat at £90 and them have got the same policy no return
update
as the auto electrician told it was a faulty sensor i bought a new sensor from fiat
had it installed and the same problem comes up
bloody sick of my life with this crap
either auto electrician doesn't no his job or I've got 2 faulty sensors ?
Hello Friend:
I have the same problem like you. I replace sensor, I have the same error code, all wiring from sensor to ecm is good, all fuses are ok, The only code is P0340.
Did you solve the problem ?
No the problem is not sorted out
ive replaced the following
crank shaft sensor x3
camshaft sensor x2
timing belt
water pump
camshaft pully
still the same problem over £600 spent so far
Just seen this thread on your error code PO340, concerning camshaft sensor. On another thread on this site, we were discussing similar points. It concerns Phonic Wheel Learn. As you've mentioned already, a new timing belt has been put in, and all additional bases covered from what you've done so far.
The fact that it has a camshaft sensor, it is very sensitive to change...........after a timing belt change, and this could be your problem with your error code being displayed. As I say, it could be your source of the problem.
The link below discusses Phonic Wheel Learn.
https://www.fiatforum.com/cinquecento...nic-wheel.html
The above link was supplied by Brummy Exile.
This article gives you the option of resetting the ECU to the new parameters after a timing belt change.
As I've already stated, this maybe your problem and it might not be, but its worth a look.
The fact that that your ECU is sending out the signal to your cam sensor, and nothing coming back, sounds omminous.
Hope this is some help.
John.
