Tipo (Classic)  ross church
ross church
Hi all
Ross Church from Paraparaumu, New Zealand here.
Classic car nut, have a small classic car business called Autoclassics.
Joined here because I have a 1994 Tipo which I love but which has developed a problem.
Need help.
It's the throttle position sensor. Car idles a bit roughly.
Cant find one anywhere. part number is 7760030.
Any help welcome.
[email protected]
Thanks.
Hi all
Need help.
Any help welcome.
[email protected]
Thanks.
Hi Ross. Look on ePER for the alternative part No.s
Then google that number..should find some equivalent sources.
Charlie
Hi
Thanks to both Charlie and Palio.
Sadly part 7760030 is listed in ePER as "Product out of Production. No replacements available".
I tried Partacus.de, but they wanted about 300 pounds for the part and then wanted another 287 pounds to send it. And they've got a lot of negative feedback, so not sure I want to risk that.
Any other ideas.
Thanks.
Ross
If it helps ePER lists the part as being fitted to the following vehicles:
Fiat PC Coupe (1994-96)
Fiat Tipo 1750-2000 (1993-95)
Lancia Dedra 1750-2000 (1994-99)
Lancia Delta 1750-2000 (1993-99)
But ePER does show an Electro Valve that is part of 7760030 (complete unit) as being part number 7740101 (replaced p/n: 60805723) which was fitted to a lot more cars than above.
Hope that helps you find what you need.
http://www.ebay.co.uk/itm/Alfa-Rome...lve-LOWE-automobil-repl-7740101-/262447223984
Thanks, appreciate that. I'll get better at navigating around ePER. Meantime, hopefully I'll get the bits so that I can stop the Tipo hunting around at idle and missing occasionally.
Ross
