Technical  Rogue warning lights
Geoffd1
Spalding
Started up our 2014 500C this morning, indicated right and I noticed in addition to the indicator warning light flashing the engine ,management and seat belt warning lights were faintly flashing at the same time. Does not do it indicating left. Externally the indicators and side repeater were all normal. No sign of any other problem.
Has anyone had this and solve it?
Model
Fiat 500 Sport Cabriolet
Year
2014
Mileage
44531
Yes very common problem best cheapest fix is to search the web for "fiat 500 speedo warning lights repair" It requires that you take the speedo out of the car and send it to them! then they fix it and send it back to you! they have to repair a known weakness in the circuit board once done should be guarantied for the life of the car! approx cost £130 -£190 assuming you can remove and replace the speedo yourself!
Doesn't cause problems if you leave it just annoying!
the repairer "current conductors" has been used to good effect by other members!.
