right door temperature wiring diagram
J
Juh
I've changed my V2 right door with a V1 door and the Outside Temperature is not connected anymore in the big round connection pins (from the door to the car).
Does someone can tell me where to connect the 2 grey wires of the T°c into the set of pins of the door connection ?
see foto:
T° cable:
Inside Door round connectors:
Car side round connector pins
I've been looking into volume 3 of the manual, for the wiring schema but I couldn't find it.
in Volume 3 that's the piece nbr 22/23 in page 847
thanks!
I found the diagram but I can't understand it.
Which pin to plug the outside temperatures cables. :(
If someone can help please?
It's in Volume 4.
http://www.babarmalik.com/Vol4.pdf
Starting page 484 (Outside temperature)
page 524, 526, 528, etc..
i would have got the exact door mate.
A Fiat Marea in a Bravo Shell..its good to be different ;)
Hehe I know ^^
But now that it just a matter of pluging these 2 grey cables into the right pins..
I hope someone know which pin ^^
only way round it would be to pull it down or maybe cut the plastic coverin (that comes out of the car) till you see the other grey wires and then try and shove the wires in or simply solder them in..or even go round it and splice into the actual wires?
why didnt you take the loom off the original door and swap it over ?
I did not change it myself. And the ¤#!µ%! bodywork guy did not do that... :(
If by chance someone open his door to change his speakers or so and can just take a look at those 2 grey cables to tell me in wich inside pin it goes.. I'll owe my beer ;)
G
1
376
K
5
492
Darren
7
493
Dark Lurker
