Does anyone know how many rh drive 500's there are still on the road compared to lh drive?
Not a lot .I have one
well I only know early stuff- N's
there were 180,000 cars produced 57-60
Of those currently there are about 220 or so known...
known means we have pictures and chassis numbers etc...
there are probably 50 or so I have seen in photos but have no details...
RHD are few and far between, ones that we have info on are probably 10-12
but I suspect (am quite sure) there are a fair few more mainly in SAfrica, NZ and Oz but we need the numbers Chassis/engine to add them
Hi all l have a RHD F. Is there a way to check it's an original RHD?
From inside the front just look where the LHD speed would have been.. the hole has to be welded up... even a good tig welder would struggle to leave no trace of a conversion, as well as the other places the swap would need welding....
unless the dash was swapped then you need to look where it would have been welded in... It could be converted so well it is impossible to tell...
So no markings or numbers on the vin? I have always believed the chassis number is stamped on the opposite side to the steering wheel on inside the boot chassis area is this correct?
Some very early cars had the numbers in a different place, think there has been a strange car with them in the center....
but I believe "all" (we have encountered) have the chassis number on the LH side looking from the front.... there was a bit of a discussion about this a while back....
The Vin does not seem to indicate much...
Both my RHD cars are stamped and plated on the right, looking from the front. It looks like @Leo6 is right (again).![]()
