MK Deano
Hi All,
My daughters 500 has an aftermarket header unit - Kenwood dmx6523dabs and I have installed a Kenwood reversing camera.
I can access the camera from the menu, when the car is in reverse, but it does not trigger the display to switch automatically.
The camera gets power from the reversing light cable, which I spliced.
Research suggested that I also needed to feed power to a purple/white cable that comes out of the back of the header unit, so again, I spliced the reverse light cable and hooked into the purple/white cable.
Confession - I used some old bell wire, as that's all that I had to hand, that seemed to be of a similar thickness.
Has anyone performed the same job with success please? Is it possible that the bell wire is incompatible, and that's causing the issue?
Any help/advice appreciated.
cheers
cheers
- Year
- 2016
