Reset Button
Reset Button
N
Nicci
Does anyone know where the reset button is on the AD182H2 radio?
It doesn't have one, maybe you mean reset button on the CD CHanger? Probably need a biro or something pointy to press it.
Joske
Depends what CD Changer you have, its normally behind the CD Changer door. Open the door and take a look.
Joske
Give me afew mins, i have the sony T69 Changer aswell. Will pop out in a mo.
Joske
I can't see it on the front anywhere, the CD Changer is under my rear seats and hard to look around it as its stuck down.
I'll try find my manual.
Also why do you want to reset it?
Joske
Just a thought but why not pull the powerlead out of the cd player or if attached/unaccesible then the fuse from the drivers side fuse board , that'll reset it surely ? .
The starter motor went on my car and then i had to re-enter the code for my radio, the magazine got stuck and so i had to release it, which i did but now the radio seems to think there is still a disc in and some one recommended pressing a reset button. The cd changer is in my kitchen and every time i recommect it says magazine so not sure what it could be. Have spoken to sony on there live chat and they havnt got a clue kept saying the radio was the problem but the radio is working fine
Ok well Magazine normally means no catridge in the CD Changer. If your using the original Fiat HEad Unit then your definately using a Connect2 Adapter to convert sony to grundig signals for the changer.
I think thats a good place to start.
Also make sure the Leads are plugged in correctly, i.e unplug and reconnect.
Joske
M
2
383
M
G
448
G
L
2
585
Gurjit
G
