Technical Replacing leaf springs.
Albert Alfvag
Uppsala
Hello all. I'm in the process of replacing my old leaf springs and adding 3cm rise blocks.
Bit I'm having difficulty lining up the plate on the axle with the coresponding place on the springs. I have attached both the front and back brackets on the spring because I felt it would be almost impossible to do after attaching the middle portion, but maybe that's wrong.
Looking for a bit of help.
/Albert
/Albert
Loosen the u bolts holding the axle to the old leaf spring , that may make moving axle easier at new spring. Do not fully tighten bolts/nuts until everything replaced and weight of car on springs.
