Technical Replacing clutch slave cylinder
The clutch biting point on my Fiat 500 Pingado was getting lower and lower. So I guessed the fluid level was going down. I topped up the reservoir to the mark and it was fine for a few days, but the same problem returned later until it was difficult to change gears, then I parked at home and I couldn't leave the drive anymore.
So I read several posts here and decided to do it myself. I bought the LUK clutch slave cylinder with its pipe from my local Eurocarparts (£40 in stock).
I set to disassemble the old part and diagnose the problem at the same time, since I didn't know what was the cause.
The photos below illustrate the procedure.
1- Disconnect the battery (positive first) then remove the belt and the battery
2- Remove the battery plastic tray
3- You will need a long socket key to remove this one. As I had none, I had to buy a new kit from B&Q.
4- Remove these clips around cables, there are loads of them
5- And press from the inside to remove these
6- Lift these bits to disconnect the ECU connectors. One at a time, it needs to go all the way up, then wiggle the socket to release it
7- The old clutch slave cylinder in place. It's quite rusty and dirty but there wasn't clear sign of fluid leak
8- Eventually I found the culprit: the link between the master and slave pipes. It was all wet from the dot4 fluid. It's located behind the left front wheel, which I had to remove.
9- The crack on the outer part of the connector, which is part of the slave cylinder pipe
10- The plastic ring which releases the connector was not moving and the solution was to start from the crack and continue breaking the outer part of the connector. I used a pile of bricks, screw drivers and hammer
11- It eventually broke in two, so I could remove the whole slave cylinder and pipe
12- I kept the original master cylinder connector in place, even though it's not looking in great condition. I cleaned and oiled it, then attached to the new slave cylinder connector. It seemed to link fine, so I'll keep it like that and see what happens.
Then I worked my way back: attaching the slave cylinder in place, then replacing the battery tray, wires, replacing the wheel, lowering the vehicle and filling clutch fluid cup.
Issues / tips: I learned the hard way that without the battery we can't open the booth! So to remove the wheel I had to access the spare kit by folding the back seat.
There is no need to remove the ECU from the battery tray as I did, it's quite difficult and time consuming. Just disconnect the cables and take out the tray with the ECU still attached.
I decided to bleed the master half of the pipes before connecting, so I wouldn't need to do it on the whole system. I asked my mum for help, she pressed the clutch pedal while I pressed the middle of the connector where there's a one-way valve. When we connect the master and slave pipes, they open the flow.
I admire who can do this type of job in one hour, as I read in other posts. For me it took about a day.
Well done! Yes those connection cylinders are almost impossible to get apart!! It’s a very satisfying feeling when you do it yourself... as for the master cylinder I have a feeling you will need to change that sooner rather than later!
And unfortunately it’s probably going to be difficult undoing that connection again!
Also removing the master is difficult due to lack of space under bonnet...
Yes you're right, if/when I have to replace either of the cylinders I won't be able to separate the connectors anymore because the quick release plastic ring is broken. I'll probably have to buy both cylinders. Or cut the connector out and then use that technique of a metal tube connecting both hose pipes, secured with hose clamps.
Well done for having a go. Never done one myself although I know the procedure. So I understand it’s better to do both slave and master at the same time.
Yes it's better to do both but I decided not to on this occasion. It seemed my cylinders were fine, because the problem I had was only the cracked connector causing a leak and making the fluid level so low that allowed air into the system.
I’m wondering if the original OEM slave is better than the luK I have fitted!?
I was bleeding my clutch yesterday and over tightened the bleed screw then the body cracked ? luckily I had another on hand! What annoys me about the luK is the bleed screw pisses fluid when bleeding! Does the OEM do this? I’m thinking about getting a factory one
Yes - it's a bleeding nuisance.
Using a vacuum bleeder helps to contain things; any method which puts pressure on the fluid sprays it all over the place, however careful you are.
Is it possible to replace the cylinder only, using the old coiled pipe. I have seen cylinders for sale without the pipe. There seems to be retaining clip where the pipe joins the cylinder?
It is possible, but quite often the pipe is fused to the cylinder and will not release (as mine was)
