replacing clutch slave cylinder
R
Rich
hi! thanks for the guide in the repair section.. but im stuck at the bit of removing the rubber pipe on the slave cylinder... i have tried for hours to remove it but it wont budge.. i have tried twisting / pulling it to no avail.... im sure im doing it wrong.... advice needed plssss......
Don't quite understand what you're asking. The rubber pipe doesn't need to be removed. To remove slave cylinder you just unbolt it at the U shaped metal pipe connection shown in the yellow circle in the guide. Before doing this you need to put a hose clamp on the rubber pipe at the position shown by the red arrow.
Frank
all sorted now.. thanks... need to pump clutch a few times not just once...
N
6K
N
M
2
433
S
G
3
494
M
M
2
466
Matthew
M
