I Had this problem a few weeks ago, hit the fan panel and the light would work again. You have to take out the stereo, then undo 2 x star headed screws, there are then 4 clips at the top of the panel that need lifting to free the panel AND 4 at the bottom of the panel which I didnt see (3 broke) but I replaced the bulb and it all went back together ok
To avoid damaging the lower clips (as I also did, however, is not noticeable when all put back together) you need to remove the lower screws which are hidden behind a lower piece of trim located under the centre console, immediately below and under the heater switch controls. This allows the complete unit to be pulled forward.
