So, you've decided to change or replace your door handles. Well it takes a matter of minutes with the use of a T15 driver.
Firstly, locate the round black screw cover, situated above the door latch and in line with the handle.
Now, unscrew the little torx bolt all the way until it stops, don't worry, it'll not fall out into the door.
Before moving the T15 push the bolt inwards, this unclamps the barrel enabling release.
Using your hand, just wiggle it out. Again, don't worry about rods or cables connected to the lock barrel, there isn't any.
Now with the barrel out of the way, firmly grasp the handle and pull it towards the back of the door, you'll feel it pop out.
Pull it outwards now until it comes out of the door.
Do the same with all other doors. The rear doors do require a long T15 driver, 80mm in length is what used.
Hope this guide helps anyone that is looking at changing their handles.
2 mins per handle is all it takes.
Thanks for reading.
Phil
Thanks for reading.
Phil
