General  Replacement Fob
The Equalizer
Hi This is my first post. :)
I have a Fiat Ulysse 2.0 EL 1998
When we bought the car 4 years ago the fob did not work, we have always used the key.
I took the fob apart to see what was wrong & found that one of the minute Micro switches had broken off. I tried to solder it back on but it didn't want to know.
So do i have to get the £150 odd pound genuine replacement or can i get one from one of the companies off the net that offer replacement alarm remotes?
Thanks & Regards
E (y)
If you go to a locksmith they can sometimes do them and you could test it while you were there. The local place does them for £18.00, but I think that is for versions which don't have the rolling code.
Worth a try, £150.00 seems a stupid amount for a key fob.
Andy
same happened to me i soldered small pieces of the wifes sowing needles then soldered the switch to them works no problem
