hi pepe, well i know the block you mean has 4 wires in i belive and is extra on top of the normal iso connectors.
i have just finished getting my new stereo working and i can tell you now that you dont need them wires. i have not even connected them up have just left that block out. i dont know what they all do but i know that 2 of them were used by the onboard computer to check that you had put in the correct
radio code. also i did have this block conected up at one point and it caused interference in rear speakers.
now as for the sub. you do not need a stereo with sub out. i thought you did and made sure my new one had this BUT i dont even have the sub out pin wired up. again i have left this disconnected.
You must check your wiring as like i said in earlier post fiat have them in different places to were they should of been. as a result i had to alter the wiring to my iso block.
the top block is fine that is just speakers FR+- RR+- FL+- RL+- this block you can just put in. the other block is the problem.
i am doing this from memory but there are 2 12v they are slightly thicker than most and are red/black and Red/white the ground wire is the thickest its black, ignition wire if i remember correctly is grey and green. these are the colors i can remember. there is also the auto antena wire, illumination wire and mute and mure ground.
remember the sub in boot is actually powered from the auto antena (elec ariel) pin. it had a built in lil amp and recives the signals from the normal rear speaker wires i belive.
the last 4 wires as i said above i cannot remeber the colors but i can describe wich one they are. on the bottom ISO the earth (black) is in the corner. next to that is the illumination wire then its one of the 12v wires(red/white) then its mute ground. now the top row of wires are as follows. above the earth in the corner is the second 12v wire (red/black), next to that is the auto antenna wire. next to that is the ignition(grey/green) then its the mute wire.
i hope from this you can work it out. also if you look at the top of the factory fity stereo there should be a lil sticker with wiring diagram on it.
any more questions just ask will try and help.
