Technical  Removing wiper arm
Venters
bairns, not bombs.
Hades by the River Styx
I'm trying to remove the wiper arm of a Marea I've found in scrappies.
Now I took off the 12mm nut at the bottom of the arm and thought it would lift off. It won't! :mad:
Is it seized on or is there more to taking the arm off than 1 12mm nut?
Hi, they tend to seize with age. Undo the bolt, take the washer out (otherwise it'll fly away) and apply some force on the arm in different directions. Eventually it will become loose and go off.
Machinemart sell a special tool for just under a tenner. If you are anywhere near Hereford or Shrewsbury I'll do it for you.
Chris
