Technical Removing the head light
Didn't think there would be enough space but had a look earlier and drivers side looks fine but will need to remove the washer neck and supporting bar on passenger side.
Washer neck is quite flexible. Truth be told I couldn't remove my washer neck. So attempted it without removal. It wasn't as bad as I thought.
Mine has a bigger battery than yours though remember! :p
I'm not to sure on that, upon checking recently (after a flat) its the biggest one that fit in the battery tray, so assuming its the same sized tray (which I suspect it is) then its the same size - 242x175x190cm for reference :p
Bring it around mine and I'll change the bulbs for you :devil:
Although you could always removed the battery instead of the bumper :)
I'll measure mine tomorrow just so you definitely know:p
Haha well I have got a couple bits I'll want to do soon.
