Technical Removing remote central locking system from car HELP!
ClockworkOrange
Right, I have finally tracked down a Barchetta being broken for spares that has the factory fitted remote central locking. It has two square shaped central locking fobs.
Can someone please give me an idiots guide, as to what EXACTLY I need to take from the donor car, and where to find said parts on the car in order to enable my Barchetta to have remote central locking.
Thanks in advance for any help!
For sure you will need the motors and the door catches from each of the doors, also the door wiring loom. The connection is in the foot well area by the speakers, think also you will need the relay that is under the dash on the passenger side. Others may be able to assist, it's a few years since I did mine.
Don't they come with central locking as standard then :confused:
Thanks guys for the replies, much appreciated. Firstly my car already has central locking fitted as standard, it operates with the key. But the main reason I want to upgrade to the remote central locking is the lock feels so flimsy and you can see the door skin flex when you turn the key! So I know there isnt much I need to remove from the donor car..but the important question is what exactly.. I did actually have a look under the dash of the donor car and saw a yellow relay but there was no aerial wire on it?
Has the donor car got the battery disconnected? If so remove the yellow relay and see if RCL still works.
Is yours missing the yellow relay in the same place :confused:
Hi MEP thanks for the reply. I removed the relay from the donor car. the RCL stopped working off the fob. However when I went to put this relay in my car I noticed that it already had this relay! I swapped them over anyway to eliminate the possibility that my existing relay was broken and it still made no difference on my car. The part number on this relay is 46426365 Do these fobs have to be programmed in or something? Also the donor car in question is a 2005 model and it has a completely different interior courtesy lamp. Is there any chance that the later model barchettas did away with the relay with aerial and incorporate it in the courtesy light? I know some other Fiats have the receiver there..
Yes thats right I fitted the relay from the donor car and the remote fobs wouldn't work, but the relay turned out to be exactly the same one fitted on the car anyway! How are these fobs coded to the car anyway?
I've attached a picture of the relay and fobs.
No CANBUS on the Barchetta.
When be bought out 2005 'B' it came with central locking (well driver & passenger door only) and I had to add remote separately. I used the then recommented Fiat accessory option (came with round fobs) and had to physically wire the remote control unit into the cars wiring. (META M320RC.
I suspect the same/similar will be installed on the car in question.
Tell me more about this remote control unit, what does it look like,and whereabouts on the car is it installed?
These were fitted as options to Seicentos, Bravos as well as others, on those it was just a case of plugging the relay into the socket and go. More than happy to try the kit on my Barch and Cinquecento for you to see if it works. Would be interested to buy too, if you want to sell.
The control unit is the yellow relay.
You need it + the fob's.
Then te locks and the door wiring. Everything else is in every barchetta supplied
If you want to use the original locks with cv and add an aftermarket remote control unit it can be done.
Just connect the door wiring, the locks.
remove the yellow relay!!
Then connect 2 wires from the door lock (into door wiring) to the remote control unit. I can look up which ones you need if you want.(do not cut but strip the wire and solder it one)
You will need to supply the unit with 12v, ground and connect the indicators to work on locking/opening.
