Technical Removal Of Rear Seats
i wouldnt say that bristol was that nice a place. Ive got my rear windows tinted and some left-over carpet over the top so when you look in, all you can see is the 3rd point of the harnesses going to the seatbelt mounting points in the floorpan
if you want to make a rear strut brace from where the backs of the rear seats bolt in the measurements are 100cm minus the thickness of plate your using for example i use a 99cm bit of 25mm round bar and two 5mm thick rectangles of steel plate. i found that it tightens the ride up a little and makes it a bit more go-kartish :) i dont know if a siecento would be the same or not. if any one wants im more than happy to weld one for some one if they can get the materials.
