General  Remote Window operation
ian001
To do the windows.
1. Turn off the car, ignition in first position (battery light off)
2. Open the window from the inside
3. Keep the window switch 'pulled' while switching on the ignition (battery light on)
4. Close the window from the inside
5. Keep the window switch 'pushed' while switching off the ignition (battery light off)
Repeat that procedure for all windows that you intend to open with a double-press on the remotes' open button.
Has anyone tried the above? I can not get it to work on my 2.2 JTD Elaganza.
The instruction appears to wrong, as when you are opening the window you 'push' the button, so how can you keep it 'pulled'? same goes for step 4&5. I tried keeping the button 'pushed' in step 3 but that didnt work either. where am I going wrong?
:confused:
ian001 said:
To do the windows.
:confused:
I think this can vary due to the software in the body computer. I think the latest version stopped the "airing" function because people were coming back to the car with windows wide open after walking away from the car and accidently holding the lock button too long.
Paul
