remote key help
remote key help
K
keval
need help my key was working fine but just yesterday when i lock it it locks beep... and then few secs later beep again ? why ?
With alarm or not ?
Did you try with a battery change ?
Members Site ---------My Site
Basically you know how you lock your car with your fob key. i click it and normally the car locks with a few seconds of BEEEEEPPP.. but now the car locks like BEEEEEPP then few secs later there another BEEEP dont know why ?
nope i havent tryd and changed the battery yet? do you think that might cause it?
It's normally w warning thr you have left something open.
Fiat Marea Weekend 2.0 20v HLX 147 83k and so far so good!
As mentioned it a warning to alert you to something open.
Check all doors, boot and bonnet. If all closed then Id assume one of the sensors isnt working correctly
what alarm fob have you got? standard factory fitted or a meta 1 with black fob button?
Mike
hi yes i have checked about 3 times that everything is closed. which sensor can it be and also can you replace the sensor? and yes its the standard fob. cheers
also forgot to say in this winter my boot is jammed and cannot open it sometimes? can that be the problem? but it has been jammed for months and i can open the boot but its hard to open at times.. its been like that for months and didnt have problem with the remote locking.. but just yesterday it started doing it cheers
The sensors are switches in the locks, so it can be the boot. Spray WD40 in the lock using the straw and lots of it, should do the job.
My money would be on the bonnet sensor. Mine did this between having the front end bump and getting it repaired.
"Doctor said to give up Keee-Babs. I said 'No, no-no'"
My Members Page
OI! Road safety nutters!! George Orwell ment '1984' to be a warning, NOT a template!
L
453
L
K
311
Keval
K
3
1K
Tommy K
T
2
766
Tommy K
T
