Hello to you all...
I have a problem with the remote control in my key. It just stop working. When I press the button, the LED on the key flashes briefly with very poor lite (which you can see only in dark), but it won't turn off the alarm or unlock the door. I tried to replace the batteries, check and clean the contacts, but that didn't help. The key has inside the chip PIC16CR83. I turned off the alarm below the wheel, with the little black key so I can alt least drive it. I also have a spare key which works but it is not programmed in to the alarm and I don't have a four digit code to programme it. Could I get it somehow? Does the code card contains it?
I have a fiat brava 1.6 16v 1998, with the original alarm.
What should I do?
What should I do?
