Hahahaha I think I drive it well :/ Ohhh I see is it that likely to happen if I just get a remap? Cos that's all I want tuning wise!! Other than that I wanna do styling mods
Depends,
The clutch will go depending on how you drive, you have hill holder so you don't need to ride the clutch on a hill and such, no wheel spins, no high revving double declutching, and it will be fine.
The gearbox is an oddball, as reuuk taught me,
, don't use power in 6th gear, and try not to rag the car in 1st and 2nd gear below 2k revs too much as you're at max torque at low revs, not good.
Change the box oil with some fuchs sintofluid 75w80 before you go for more power, will helps loads.
I'll be fitting my new hybrid turbo next week and going for a custom map, should see 210bhp and loads of torque, torque needs to be limited though for the boxs sake.
On the stock turbo, both decats, cone filter (honda s2000 filter with a reducer is best) egr blank, and preferably a larger intercooler, you'll see 170/180bhp from a map.
Engine is good for 250bhp before it can't breath anymore because of the 8v, but the box wont let it go past 220 anyway.
Hope that's answered absolutely everything hahah
